That's quite comprehensive, great thanks. So in short I think Noble is better than Chord and Chord better than Hulk?
More importantly, Can you elaborate on the differences between the beryllium plated drivers for 3001 Pro, 4001 & 17th as well? I believe the 3 are not identical but not sure what the actual difference is. It is difficult for us to compare. For my 17th, the sound already got a huge improvement from Day 1 to Day 3. Believe most Dunu earphones rqquire a long burn-in...
Well, we don't want to make any assumptions about whether people will think the NOBLE is better than the CHORD or the HULK. There will always be people who believe cables made of a single material like the HULK is better than a mix strand cable like the NOBLE or CHORD, and vice versa.
What we can guarantee, is that we always try to price our products to give as much value as possible to the consumer. A hand woven, mixed-strand wire like the ones found in NOBLE and CHORD is always going to be more difficult and costly to source and make than the HULK. The extra copper shielding layer in the NOBLE is more difficult to produce than the unshielded CHORD. We don't attempt to price according to consumer expectations of sound.
Many people have asked us why we decided to offer aftermarket cables when we are earphone specialists. The reason is that many of our fans, especially in China, have urged us to be a guarantor of authentic sources of cabling. It is very easy to source cables from 1688, Taobao, and JD, but it is difficult to determine whether those spools of cable are authentic. Our customers can be confident that the wires we source have authenticity.
As for the differences in the Beryllium-coated drivers between the DK-3001 PRO, the DK-4001, and the 17th Anniversary Limited Edition model,
@tomscy2000 is mostly correct, but let me fill in some details! First, we have to make sure you guys understand that there are lots of factors that impact sound performance in our products. Without giving too much away, the basics are:
- Initial (uncoated) diaphragm mass, diameter, and surface structure
- Magnet and voice coil configuration
- The type of diaphragm coating: we are proficient in titanium, liquid crystal polymer, carbon nanotube, and beryllium
- Single or dual-sided coating
- Venting and bass reflex
To answer your question, the 17th Anniversary Limited Edition model has both a thicker Beryllium coating and a different base diaphragm than the DK-4001. The DK-3001 PRO's base diaphragm is the same as the DK-4001's, but the Beryllium coating is thinner. Lastly, the DK-3001 PRO does not have ACIS, so the quality of the bass is also going to be different.
