Dumb question: Where to get replacement foam pads for earbud phones?
Dec 11, 2002 at 8:04 AM Thread Starter Post #1 of 5
engk
Sorry. willing to buy them from those who have exra sets. Thanks.
Dec 11, 2002 at 11:18 AM Post #2 of 5
good question. I've almost lost the pads of My Senn MX500s several times. I would think Radio Shack maybe? or you could always jump on ebay and buy a really cheap pair just for the little pads.
Dec 11, 2002 at 2:38 PM Post #3 of 5
Radio Shack sells them in a pack of four for under $2.
Dec 11, 2002 at 2:41 PM Post #4 of 5
yup, that's where I bought mine. They actually sound quite good with the MX500s, especially when you "double" them. For me, the stock ones on bottom/radio shack on top fit/sound best.
Dec 11, 2002 at 5:33 PM Post #5 of 5
Thought about buying a cheap pair, but cheap ones don't usually come with the pads. Thanks for the info, you guys are great!
