I3eyond
- Dec 2, 2005
If not, what's a cheap amp that will give me the full sound of these cans?
Originally Posted by GreatDane /img/forum/go_quote.gif PA2v2 will sound good with 80 Ohm 770 until you hear them with something better. That's my nice way of saying that I didn't like the combo...not enough power imo to do them justice at levels nearing "unsafe". |
Originally Posted by I3eyond All I can find online is the 250 Ohm version... |
Originally Posted by I3eyond /img/forum/go_quote.gif What did you find was missing when you upgraded? Also, will the 250 Ohm version definitely not be well-driven by the PA2V2? .. All I can find online is the 250 Ohm version... |
Originally Posted by noorudeenshakur /img/forum/go_quote.gif Yes, The Amp is great. ![]() |
Originally Posted by GreatDane /img/forum/go_quote.gif I bought the PA2v2 for use with IEMs...with my mistake of not having Gary set the gain low...so of course it was tested with full size cans. I found that it had poor control of bass and would seem to "clip" when attempting to drive my 80 Ohm 770 to levels that I would normally use with AC powered amps. If you listen at low to moderate levels the PA2v2 is just fine but try to crank out some bass heavy music and it fails. I bought my 770 Pro/80 at GC too. |
Originally Posted by ph0rk /img/forum/go_quote.gif I find my nano can drive the 770's louder than I care to listen unamped. I have the limiter set with about ~72ish db with soundcheck for my hd-25's, 65-67 dp w/ soundcheck with dt-770's - volume limit is around 50%. I tend to prefer low volume listening, though. |
