alexpea
- Jul 13, 2006
Ehm.. How about the fact that a motorcycle-helmet contains breakable fiberglass - which I doubt is able to drill a whole in.. I think the operation will be VERY dififcult. And even if you manage to do it, I still think the sound would be terrible. I would go for IEM's !! If you so desperatly need to test this theory - do as other have suggested. Use the KSC-75's to check the theory. Glue them into the helmet, and play them loud.
On the other hand - if you manage to make the pads LIE on your ears, and not just play sound into the open inside the helmet, that would be awesome. If you manage to pull this off, then make sure to post some pics!! I would check up first if this is legal, and if it actually is, then you should contact Beyerdynamic + a helmet manufacturer and ask if they could sponsor you with the project. Cuz damn, if THIS is legal, then it's a potential gold-mine !!
