dt 770 pro 80 ohm rattle issues
Jan 8, 2010 at 3:39 PM Thread Starter Post #1 of 3
tommyGUN
Hey guys,
Just got a pair of these headphones and I notice that when the bass hits hard, the right can has a rattle to it. What could be loose? Should I send them in or return them? I just got them like 3 weeks ago and it just started a week ago. I burned them for about 100hrs at a normal listening level. I use them at work, so I'm listening to them at normal to low levels. They are driven by a small amp. Hope this all the info you guys need. Any help is great.
Cheers
Jan 8, 2010 at 4:32 PM Post #2 of 3
I had this exact problem when I was not using a halfway decent amplifier (they rattled out of the stx at low volumes ocassionally). Stopped hapenning when i got a LDMKIII (pretty lowfi)
Jan 8, 2010 at 9:35 PM Post #3 of 3
Underamping might cause this. Another option -not very common with Beyers- is that a hair has found its way to the drivers.
