You can set the PCM sample rate to 88200 instead if that's what you want to downsample to. Or keep that as it is and add a DSP resampler to whatever rate you want. As long as you aren't setting the SACD PCM sample rate to 44100 and resampling UP afterwards it's ok.
So I have to use the resampler after all?? Anyhow, thanks for the advices!
