Double Helix Cables Thread
Dec 13, 2016 at 9:39 PM Post #1,186 of 2,056
Wow the prion 4 just gets better with a bunch of hours.
Dec 14, 2016 at 4:23 PM Post #1,188 of 2,056
Holy TOTL cables! lol. I hope it's worth that kinda spondoolies :) Mind you, I was eying up a Symbiote IEM cable myself over Black Friday weekend, just couldn't pull the trigger though.
Dec 14, 2016 at 10:27 PM Post #1,190 of 2,056
Haha, me too. I probably added it and removed from my cart half a dozen times! I was eyeing the Symbiote Elite though, which unfortunately is a step-function more expensive than those for the normal 2pin IEM connectors...
Dec 15, 2016 at 9:18 AM Post #1,191 of 2,056
I am looking for a reasonably specific length cables for my HE1000, which is not too easy to find, and I want to blind test to see if I can actually hear any difference between these and the stock cables:
What is meant by "choice of braid: 4/6/8/10` four wire braid". What does 4/6/8/10 represent?
Also: under the "molicule SE" at the top a cable is shown with two wires per channel, below a cable is shown with 4 wires per channel? Yet they are both four wire judging from "choice of braid: 4/6/8/10` four wire braid""?
Dec 15, 2016 at 9:23 AM Post #1,192 of 2,056
  I am looking for a reasonably specific length cables for my HE1000, which is not too easy to find so:
feet
Dec 15, 2016 at 9:34 AM Post #1,193 of 2,056
Seriously... I read "Choice of braid" and was trying to on how it effected the braid.. Metric units are the standard where I am so a ` is never really seen here to represent length.
And what about:
  Under the "molicule SE" at the top a cable is shown with two wires per channel, below a cable is shown with 4 wires per channel? Yet they are both "four wire" judging from "choice of braid: x` four wire braid"?
Dec 15, 2016 at 9:54 AM Post #1,194 of 2,056
you order 4 wire you will get 4 wire. 8 will get 8. I have never ordered HP cable other than c4 or prion 4 and iem cable other than occ type 4 litz 8 braid or fusion 8 braid.
Jan 19, 2017 at 3:32 PM Post #1,195 of 2,056
New DHC Peptide v2 copper litz in house. Using with my AQ Nighthawks.
Full report in time.
Feb 5, 2017 at 9:17 AM Post #1,197 of 2,056
I just ordered my first DHC cable, a Molecule Elite silver litz for my Ether C Flow headphones.
I'm feeling a mix of excitement and guilt... If my wife finds out I just spend 500$+ on headphone cable she will cut my... hem... "XLR connector".
Feb 7, 2017 at 12:53 AM Post #1,198 of 2,056
I'm planning the same purchase for the Ether C Flow (but with a 3.5 mm connector); look forward to getting your impressions
Feb 9, 2017 at 8:32 AM Post #1,200 of 2,056
That will happen in 2-3 months, unfortunately. That's a long wait...
if your lucky could be 4-6 months. I put an order in nov 25 for silver type 4 litz 8 braid, I'm hoping march or april, maybe may.
