Don't be shy, contact us directly with problems with your FiiO!
Discussion in 'FiiO' started by joe bloggs, Mar 2, 2015.
7 8 9 10 11 12 13 14 15 16
  1. Solasuke
    Hi FiiO,
    Yes I think so. I am using the adjustable volume on the line out, but I'm worried about damaging things I plug into it - I'm not very experienced with line outs and impedance. Is it possible to fix the headphone jack without damaging the X3ii?
  2. FiiO
    Dear friend,
    Damaging? You won't damage it if you repair it properly. You may need to replace the headphone jack using the slodering iron.
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official http://www.fiio.net/fiio http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
  3. Eazy E
    Thank you for your reply. Is there a specific brand of TF card that is recommended?
  4. FiiO
    Dear friend,
    Generally, we will recommend the Sandisk card. But we can't be sure whether it may help.
    Best regards
  5. XP_98
    Hello FiiO
    I own a X5-III since a few weeks, and I noticed a short crackle before the beginning of a new audio file, when I browse among folders. I did not notice this when I play several files on a row in the same folder. I tried to turn gapless playback on and off, but it makes no difference.
    My files are on the Sandisk card that I previously used with my X5-I, but with the X5-I, I never encountered this issue...
    Any idea ? Could this be solved with next fw update (l'm under 1.1.6) ?
    best regards
  6. FiiO
    Dear friend,
    Did you turn on the Vipper effect or the issue happens in switching songs with diffrent sampling rate?
    Best regards
  7. XP_98
    Hello
    No différence w/wo Viper.
    I use only FLAC files, mostly level 5 compression, and a few DSD. But of course, the comparison with X5-I (no crackling) was about FLAC files...
    Must be something else...
  8. FiiO
    Dear friend,
    About the slight crackle that occurs occasionally during playback
    It is one of the HiFi audio players' core features to support different types of music formats and sampling rates. And each time when the DAC chip change the sampling rates, it will need to reset itself, which can cause a slight crackle in the sound. This problem cannot be totally prevented, unless converting all the songs to the same format and sampling rates before playing them (just like what the Apple iTunes will do). But doing this will make the HiFi player lose its biggest advantage.
    Best regards
  9. XP_98
    Thank you for your answer. But then, why did these crackles not occur with the X5-I, with the same memory card containing the same audio files ?
  10. Les Paul
    On the X3 mark III connected whit bluetooth after restart from sleep mode there is no audio until I push volume buttons !! Bug of software ?!!
  11. FiiO
    We have reported to the engineers about that and they may need to confirm the issue first. Thanks for the kind feedback.
    Best regards
  12. nexus1991
    Hi,
    I own Fiio X5 2nd gen. Since your last FW update ver. 2.1 the player would not go into Idle Standby mode, if Fast Forward is pressed. The battery drains pretty quickly.
    Is there a solution to this issue?
    Thanks.
  13. FiiO
    Dear friend,
    You may need to active and set the idle standby mode again after using the fast forward.
    Sorry if bringing inconveinece to you.
    Best regards
  14. gimmeheadroom
    Hi,
    I have several FiiO items. I'm mostly happy with them. Two issues:
    1. My x5ii does not show the correct bit depth in USB DAC mode. I understand this is a known issue, but when will it be fixed?
    2. My x5ii is recognized and works fine except for the issue above. But my new FiiO X3 Mark III is not recognized by a very recent Linux kernel 4.14.18. This is annoying because I can't use it with my K5, which is the reason I bought it.
    Thanks.
