HeyOK1000
- Jul 10, 2004
I'm using the Doge 6210 amp in the mindset of a trial period and most likely possible return. As I'm NON-techie I do not and cannot understand inconsistent sound volume changes related to EL84 tube rolling.
In using the power tubes that came with the amp, sound volume quantity is "appropriate" and even loud (with my AKG K701) at 9 o'clock. Even the volume varies with the 3 ohm selector. But quality rather harsh, as stated by other posters regarding this amp.
At first I tuberolled various vintage 12ax7s, finally settling on RCA Command 5751s to downgrade the harshness - all this using the supplied EL84s.
As recommended in this forum, for improved quality, I tube rolled the EL84s, using Amperex 1950s D getters, RCA blackplates and General Electric 60's ones. Yes, the sound got smoother but then came radical sound drops!
The Amperex got up to "near decent" volume - and not even that much at 2 o'clock - the bass starts to distort and in general, higher passages or crescendos distort as if the amp is being pushed too hard. The three ohm settings made little difference as all 3 sounded alike (different from the supplied tubes where it obviously varied). Even more startling, was that the big stage sound of the supplied tubes (with nice bass) recessed into the distance with the Amperex even though the "picture" was clearer. Singing voice was nice but and if the volume could have matched the supplied tubes everything would have been paradise!
There was a little more volume with the RCA and GEs - about 12 to 1 o'clock but still the same problem when cranking for more.
I switched back to the supplied tubes and the massive volume was back to "normal." When I tuberolled EL84s on other amps there was no volume discrepancy but definite improvement of vintage over current tubes. This is the first time I've ever had this situation.
Can anybody out there explain this? It is as if the supplied tubes were (to use an analogy) old highly efficient speakers used for flea powered tube amps and my vintage tube stock equaling 1970s speakers used with solid state amps.
I do want to say that I love this amp having absolutely NO HUM as opposed to the reconditioned single ended 6BQ5 amps I've experienced.
Thank you for your time and any and all replies.
