PaganDL
- Feb 1, 2016
Hi @Heinstar,
As a few others have said, in all honesty, your Sescom should be more than fine, they make decent to good gear.
I suggest looking into Pro Audio gear for possible solutions for more interconnectivity with little to no detrimental signal degradation.
This goes for you too, @cc chabba
In this area, patch bays come to mind though most support TRS plugs but getting adapters are easy enough so you might want to look into these then a switcher becomes largely irrelevant.
Otherwise, a cheat I do for audio signal distribution in my audio chain is from my DAC's (Lexicon Alpha) Head Out, I run a 3.5 mm to TRS Cordial Cable into the Presonus HP 4 input in the back which in turn, sends the audio signal to any of the HP4 Head Outs & the pass through in the back to a Hifi Amp which drives Passive Speakers.
Presonus HP 4 can also be infinitely chained together with no signal loss or degrgdation so if you need a multiple affordable solution where RCA &/or 3.5 is the only requirement, then I suggest looking into this head amp.
There are 3.5 mm to RCA cables which Cordial or anybody for that matter, especially in Pro Audio can make or have off the shelf, which can help add more RCA support.
Otherwise, from my DAC, all audio is sent to my Monitor Controller, Drawmer MC 2.1 which sends signal to Powered Speakers & can also support balanced outputs for head amps.
Feel free to ask questions if you need as I am very familar with the HP 4.
Hope this all makes sense too.
Hope you have a great day !
