Does lossless have an advantage over lossy formats when using equalization and crossfeed?
post-12491216
Post #16 of 17
Giupy
Thank you for your input, now I worry a bit less.
Is there a way to add EQ (or other VST plug-ins) after compression to lossy when converting files, (if the file is to be encoded with the processing)? I want to make a library with files that have encoded EQ and other VSTs like castleofargh suggested.
Thanks for the tip. I am setting up foobar now :) Maybe you can also help answer my question above regarding adding EQ post compression.
There is, but it's pretty complicated. There is software that can do both EQ and conversion, but we're talking complicated stuff and it takes a pretty long time, since it has to be done individually for each track. I believe Adobe Audition is capable of doing that, but I'm sure that there are cheaper alternatives.
Also, iTunes allows you to set a different EQ for each track. Maybe that would be a simpler alternative. I wish Foobar allowed for something similar.
post-12492771
Post #17 of 17
Jon Sonne
Member of the Trade: Lucky Ears
Thank you all for your suggestions and answers to my questions! Its nice to be in such a friendly forum
Reactions: castleofargh
