Does interconnect RCA output from hifi have voltage risk ?
Jul 14, 2007 at 11:38 AM Thread Starter Post #1 of 6
lerio
I prepare the interconnect cabling between my home hifi system and my already beloved futur Cantate and i wonder if the end of the cable (the 2 RCA who will connect to Amp) have voltage at high level ? do i must avoid them to be in contact one with the other one ?
Newbie question yes
Jul 14, 2007 at 4:10 PM Post #2 of 6
Normally there is no harmful voltage, 2 to 3V RMS from a source when playing but some modified CD players containing tube output buffers may produce a high voltage glitch which is quickly decaying after turning on and does no harm but might be unpleasant when touched. In your case, you can catch a spark from static electricity when any of the components is grounded but the charge goes down the ground pin of the interconnect and if you're not "charged" like from the carpet, nothing will happen.
Jul 14, 2007 at 4:13 PM Post #3 of 6
I don't think it's modified with tube (a normal Sony hifi system) so should be fine
Thank's
Jul 15, 2007 at 1:26 PM Post #4 of 6
The risk of harm to you is minimal unless there is stray voltage conducted which is rare.
Jul 15, 2007 at 1:46 PM Post #6 of 6
How to know ? other possibbility then what majkel said "modified CD players containing tube output" ?
As i said it's a normal small Soni hifi home system, nothing special or modified here
