Do you know how to connect a ext. hard drive to a stereo receiver?
Feb 5, 2008 at 6:12 AM Thread Starter Post #1 of 10
arnesto
I have all my music files on a external hard drive now and I want to hook it up to my stereo receiver.
One option is to go ext. hard drive=>laptop computer==>USB jack to external DAC==>stereo receiver
But I don't want to use keep my computer hooked up to my stereo all the time, and I wanted to be able to select music files to play by remote control.
Someone suggested getting a Transporter, but I don't like how I have to keep my computer on all the time and I have to connect by Wi-Fi.
Does anyone know another solution so that I can use ext. hard drive==>???(to connect to)==>stereo receiver.
Feb 5, 2008 at 8:05 AM Post #3 of 10
There are loads of multimedia external drives out there that can operate as stand alone units. I got one off ebay that even has its own remote control. You can see what you are accessing on the drive via a built in LCD panel on the drive case.
Feb 6, 2008 at 12:21 AM Post #4 of 10
If you dont mine me asking how much did it set you back?
Feb 6, 2008 at 5:03 AM Post #6 of 10
Uncle Erik, the Squeezebox is similar to the transporter. You need to have your computer on to play music files on your hard drive. And I wasn't too crazy about having more invisible air waves bombarding me(Wi-Fi). I prefer to have things wired.
Herandu, sounds good, but I haven't seen anything like that for consumer use.
GAD, are you able to control which songs you can play with a remote control?
If you can then I think that might work for me, but I have not seen a receiver with a USB input. Which receiver are you talking about. I was leaning toward getting a 2 channel integrated amp.
Feb 7, 2008 at 2:21 AM Post #7 of 10
Yup. I plug my thumb drive into it all the time. You control it all with the remote. It comes up on-screen. The problem is that navigating 10,000 songs or even 1000 artists is all but uselessly slow.
The PS3 works much better in this regard.
GAD
May 3, 2015 at 6:42 AM Post #10 of 10
  If you do learn a solution, please let me know.  I'm trying to do exactly the same thing.
Squeezebox Touch, now discontinued but lots available via eBay etc will do this.
The Roku 3 will do the same. Western Digital HD TV live as well
Google for 'media player usb hdd' or similar terms
