Do you hear the difference? (take the 128kbps / 320kbps test)
Jan 15, 2013 at 5:32 AM Post #16 of 25
stv014
If I recall correctly, some problems were found in this test, the files are not level matched (the higher bitrate versions are slightly louder), and people could also tell which file is being played without even listening to any actual differences in the compression because the high bitrate files simply take longer time to load.
Jan 15, 2013 at 5:45 AM Post #17 of 25
H20Fidelity
:wink: Indeed they do, and that was part of the test and my thread to see who worked it out first. The 320kbps file take longer to begin and that is a dead give away, once you get the timing right after a few tests prior you can pick it everytime.
And for that you win........
One free 128kbps song download of your choice.. PM me to redeem your prize.
Jan 15, 2013 at 7:56 AM Post #18 of 25
SoundPon3
There's my score
I think it was the same song that got me (think it was Hard lovin' womanbut I'm actually surprised at what I got.
 My full rig isn't up and running yet (still waiting for DAC and amp, I guess on-board will have to do) so I'll re-take the test then (even though it might not be much of a factor)
As for loading time, well I knew that would be a factor but I only thought of that at the end of the 10 trials
Jan 15, 2013 at 6:07 PM Post #22 of 25
KamijoIsMyHero
I thought it was the software giving off a delay, I tried alternating fast between the ABX and there was a delay, so I gave it a second to load, is the delay a characteristic of lower bitrate?
I'm preparing some files now...
So far I've got : One all acoustic bluegrass song, one fairly heavily layered ambient glitch song, and now I'm looking for something fairly simple with not a lot of loudness going on, and without an audible tape hiss.
how about some heavy metal? something fast and crazy
Jan 15, 2013 at 6:18 PM Post #23 of 25
chewy4
Sorry, closest thing I have is some fairly heavy prog rock. And it's got some tape hiss.
I'm trying to avoid anything with tape hiss so people can judge off the musical content itself rather than the tone of the background noise.
EDIT: OK, found a nice acoustic bit.
EDIT2: Finished setting it up! http://www.head-fi.org/t/646411/lossless-vs-128kbps-mp3-vs-320kbps-mp3-blind-test
