Do velour earpads bleed lots of sound?
Aug 19, 2014 at 11:24 PM Thread Starter Post #1 of 3
potatochobit
I just installed a pair of velour earpads since everyone seems to like them
but now when I wear my closed headphones, I can hear everything going on around me
did I just change my closed headphones into open ones?
Aug 20, 2014 at 12:33 AM Post #2 of 3
PurpleAngel
California
  I just installed a pair of velour ear pads since everyone seems to like them
Which headphones and which Velour ear pads do you have?
I really doubt anyone around you can hear you what your listening to anymore then when you used non-Velours.
Aug 20, 2014 at 12:46 AM Post #3 of 3
potatochobit
hello
thanx for the reply
these are audio techincas with some HE sometihng velour pads
many people say velour pads retain less heat making them more comfortable
because they are breatheable and let air in, I guess they are letting in lots of sound as well
I can definitely hear everything outside the headphones, it could be also due do the padding being stiff
but they dont seem to leak sound anymore than normal
I had someone help me test while they listened at various volumes and I checked from different locations
so all in all, everything is Ok and this is pretty good upgrade
not sure how to clean these though
