Do SRH840 pads affect SRH440 sound?
Jan 2, 2010 at 7:36 PM Thread Starter Post #1 of 5
Marximus
I just pulled the trigger on the 440s (curse you, Head-Fi!), and I'm big into comfort (My DT990 Pros are acceptably comfortable); I read that the 840 pads would be better on the 440s, comfort-wise, but I was wondering if they'll affect the sound. Additionally, does anybody know if there are there other pads that would fit the 440s? Velour? DT250? DT770? Thanks for any help.
Jan 2, 2010 at 7:38 PM Post #2 of 5
I've tried the 840 pad on the 440, and imo I feel the sound is very unbalanced afterwards. The bass is definitely improved with a lot more punch, but I feel the overall sound to be duller and really bass-oriented afterwards. I decided to stick with the 440 pad on my 440.
dL
Jan 2, 2010 at 7:48 PM Post #4 of 5
Are you inquiring about the pads or the actual 840 headphones?
dL
