liamstrain
Member of the Trade: The Audio Guild
- Sep 18, 2011
So your stance is that cables may make audible differences in blind tests, but not due to material or construction choices? I don't think anyone's refuting the claim that cables
do make an audible difference... It's just that the difference cannot/have not been detected in properly conducted blind tests.
I may have formed my words clumsily. The fact that properly conducted blind tests have not shown a difference, leads to the conclusion that it is not material or construction that creates the differences people hear when doing sighted swaps, etc. Trying to cover all those bases, I may have given the wrong impression. Apologies.
Yea you don't need to do a separate experiment because the data favours your stance, but it'd be interesting to conduct a blind test to see if you can detect the differences.
If your test results go against your original hypothesis then redo the test a couple of times just to make sure. If the results still go against your original stance, then I don't
see how you can remain on the same camp anymore.
And because mine is the null hypothesis - it is contained already in the formulation of theirs. That the evidence favors mine, is just a happy coincidence.
It might be interesting to do my own tests and see what I hear or don't hear. But you've named a LOT of if's before I'd have to re-evaluate my position. And frankly, if the preponderance of evidence conflicted with my own results - I'd probably have to accept that it is more likely there is a flaw in my methodology, than that I had evidence to truly refute all other studies to date. At the most, I would have to admit that subjectively, I found differences - but i would not expect anyone else to be convinced by my results.
