RockStar2005
I'd like to ask the people of Head-Fi if there is any truth to this, or no? Please make sure to elaborate on your answers with details and specifics.
Thank You!
Thank You!
It really depends on the response, not so much those specs you mentioned. The thing is though when one designs the drivers the impedance can affect sensitivity (just one of many factors though), and among the many factors that can affect response and sensitivity is the design of the driver diaphragm. Lighter can be good, but can make it more prone to damage, so they have to reinforce without adding too much weight, but then that adds to the cost.
Think of it this way - it will be like designing a sports car or bike chassis. Going for a full carbon fibre monocoque puts you in Ducati MotoGP or F1 territory, which would be fantastic for handling but harder to sell in larger quantities, so you have to mind how much goes into it also.
Hmm ok. So your final answer is there is no DIRECT correlation then?
Thank You!
Ok so I guess having higher impedance/lower sensitivity is NOT a guarantee for better sound, but the other factors involved like quality etc are the real reason why high imp/low sens 'phones sound better.
Thanks to all who contributed!! Great info!
I would agree with the consensus here, but note that historically this probably had some indirect correlation and thus basis in reality (e.g. it isn't just arbitrary marketing claims). The "why" is not that high impedance/low sensitivity was for any reason "better" due to its own virtues (as has been explained here by others), but that most of the higher end cans of yesteryear were usually high impedance/low sensitivity models (go look at older Sennheiser, AKG, Beyerdynamic, Koss, etc products as examples). More recently it seems like most manufacturers are trying to do lower impedance and/or higher sensitivity cans that play nicer with mobile/portable devices as opposed to assuming that users are predominately hooking headphones into some desktop-based unit (like a receiver or integrated amplifier). That doesn't mean there aren't lots of exceptions - as far as I know Grado has never produced a "high impedance" model, and many high-end Sony and Audio-Technica cans (even going back years) are low impedance as well. Also keep in mind that outside of Beyerdynamic (who offer multiple impedance versions of a few cans, like the DT880), there will be a lot of other, bigger, differences between a hypothetical low impedance/high sensitivity can and a high impedance/low sensitivity can - for example a "classic" comparison between the Grado RS-1 and Sennheiser HD 600; there's a lot going on there beyond just impedance/sensitivity that makes those sound very different.
