mcandmar
- Jul 5, 2013
This would make a great April 1st thread. Apart from the obvious stupidity of the entire notion there is one possibility that could effect the sound output. Any electric motor will produce noise back into its power supply as it is running, it can be a motor driving the hard drive spindle, or a fan in the computer, they all create a ripple in the power supply to some degree.
The more current a motor requires, the more prevalent this will be. So a great big fan, or a big heavy multi platter drive will have a larger motor which can be noisier. Now lets say your are using an internal sound card, or a USB powered DAC that is powered from the same machine, in which case a measurable noise floor difference is a vary real possibility.
Higher end hard drives, especially those with higher spindle speeds in the 10-15k category will indeed be nosier than a cheap low power 5400rpm drive, or a small 2.5" laptop drive so the entire notion of a hard drive having an effect on sound quality doesn't seem so stupid after all.
Real world example, i built a USB isolator and low noise power supply to run my USB DAC's as there was a measurable, and audible difference. Now that i think about it my PC has five big 120mm fans, and six high end 7200rpms hard drives whizzing away in there, and the 5v USB supply was noisy as hell.
