eucariote
- Oct 15, 2009
This has been asked before at Head-fi, but the answers have been all over the map. I've collected the answers given to this question, ranging in order from no leakage to excessive leakage, so you can see the remarkable lack of consistency and the reason for my continued confusion:
"the D2000 doesn't leak any sound"
"They don't leak very little, if at all."
"this phone doesn't really isolate well at all, but there is no sound leakage"
"The isolation for outside noise is not very good on those cans, but they leak almost nothing with moderate sound volume"
"2000 does leak if you do listen to them at high volumes"
"i wouldn't worry about sound leakage unless you are one of those people that listen to 80+ dB"
"They leak a reasonably ammount, specially with higher volumes, More so than my DT990s"
"Interest lost in D2000, can lack bass slam...? and it may has enough sound leakage?"
I will be using these headphones in a study in my house with my wife working nearby and do not want to disturb her. I don't listen to music excessively loud, but loud enough that I get looks of horror and concern when I listen to gratuitous rock music on my SR225s (sorry, no decibel meter handy). I've already bought and returned one set of closed headphones because of excess leakage (DT 250) and so would like to know in advance this time.
So, once and for all, will Denon D2000's leak enough sound that they will be heard in a quiet study when listening to music at a moderate volume? Thank you Denon owners for your help.
