bfreedma
The Hornet!
- Feb 3, 2012
You are repeating the comfortable beaten old path of dismissiveness by saying 'prove to us objectively that you are hearing what you are hearing' which is very similar to saying 'show the measurement proving that your whatever speaker sounds better than whichever other speaker', where their freq curves are highly identical, so is phase response, and the waterfall is not showing much difference either. Do you buy speakers and stuff based on TS or other parameters such as THD alone?
We're not talking wireless here, at least I am not, I will also repeat what I stated before; fiberoptic versus UTP on the same two switches in the same setup and there is an audible difference I cannot explain, but that does not invalidate the observation. Obviously if the precious measurements would have been any different the underlying cause would be closer to us, what s happening here is akin to someone with a yardstick calling out 'see the earth is flat because my yardstick does not need to bend to measure the ground we're walking on', he was right with that observation but in the larger scheme of things that observation ultimately proved not to be connected to the truth that the earth is round.
I'm not saying the measurements and protocols are incorrect, I've looked at packets lost etc (and did not see any lost in any working network) and my data files do not look brighter or darker or better in any way or shape through fiber optics. Still there is an audible difference and that observation is reported by a good number of people, some of which with very inquisitive nature, and to great (well huge) expense by some. To be clear, we're talking regular 'pro IT' components, stuff like stacking layer 2 switches, not potential snake oil bits and pieces with any audiophile label stuck to them. Why do files played from RAM sound better than from SSD , and why do they sound better when played from Intel Optane, the checksum is no different.... Do you really believe folks are buying Terabyte or so Optane PCIe discs at a price tag of a couple of grand each because they are gullible?
Yes, I believe that people are buying these expensive black boxes because they are gullible and lack the domain knowledge to understand why the manufacturers marketing claims aren’t technically possible.
Files played from RAM do not sound different than those played from SSD. Lack of your presentation of any evidence aside, that claim ignores the multiple buffers the data will still pass through, so not sure how anyone would see improvement from a source so electronically distant from the output,
Outrageous claims with no evidence will be dismissed quickly. And throwing comparing speakers in to this is the usual attempt at deflection. Of course different speakers can and will sound different. Speakers are also heavily impacted by room acoustics, which electronics are not. I never stated otherwise. I’ve never seen anyone here state otherwise. The discussion here is whether a specific product (audiophile network switch) can improve audio. It can’t because the 802 standard ensures it.
If you believe that the standard that currently enables trillions of bytes of data to successfully traverse global networks is incorrect or incomplete, put together the appropriate technical documentation. I was previously on several of the 802 standard subcommittees, so can quickly get it to the right people. It will need to be evidence based, so hard data documenting the improvements you suggest audiophile switches provide outside of the 802 standard will need to be included.
