DNA Stratus 2A3 amplifier - first impressions
Discussion in 'High-end Audio Forum' started by budx3385, May 12, 2012.
247 248 249 250 251 252 253 254 255 256
  1. adamaley
    I sold by Stratus two years ago but was wondering whether any Stratus owners have tried out Psvane's new Acme series 2A3s. I find their Acme 805s very exceptional, and their Acme 300B has been favorably compared to heavy hitters like the holy grail WE 300Bs. Considering their relative affordability, the Acme 2A3s will be worth a try in the Stratus.
  2. RubyTiger
    Good to see you back Stuart1927. Was wondering what happened to you. Revealing photo's! How difficult do you think it would be to replace the input driver socket? Was considering doing it myself but a little hesitant.
  3. stuart1927
    I'd be quite happy to do the input tube socket. Access is about the same although the socket is obviously smaller so perhaps a bit more fiddly. As long as you set it up well with good light and take your time it should be fine. I got one of those workstation units with a magnifying glass and light. If like me the old eyesight is a bit suspect....this helps a lot! My soldering isn't great, but I got there eventually!
  4. mwr2700
    I recently purchased a used Stratus and sent it to get the upgrade. What an amazing amp. As I said to
    Donald:
    With my previous amp, I felt like I was sitting in the first or second row of a concert. With the Stratus,
    it sounds like I'm in the orchestra. The detail is more pronounced. Like hearing the bassoon being keyed, the
    movement of hands on the neck of the cellos, breath inhales on the flute, all make listening a much more lifelike
    experience. And all this on stock tubes.
    I'm psyched.
  5. Bowtieguy
    It is an awesome amp, and Donald's an awesome guy to deal with. Always helpful and never too busy for you. I've had my Stratus for maybe five years now, and every time I listen to it, it's a thrill. One thing that I think doesn't get enough notice is how dead silent it is. A lot of amps hum or make other noises (the Woo WA22 was frankly awful in that regard), but this one doesn't. And the sound is incredibly lifelike,
  6. attmci
    Oh, no. You must get bad luck.
  7. RubyTiger
    I noticed a little hum the other night and it turned out to be the rectifier. It never reached the headphones though. I have been experiencing the need to turn my volume a bit before the sound begin's to come up. Doesn't hurt but it didn't used to. I need to fix it and replace my input driver socket.
    By the way, thank you for the encouragement to change the socket Stuart. I know I can do it but I just can't stop listening! This year has been steady cable upgrades and it's never sounded better.
  8. stuart1927
    I meant to ask you....what tubes are you running these days?
  9. RubyTiger
    I'm running one of my 6n1p's, the EML 5u4g and Acme Supreme 2a3's. The Supreme's are good stuff. Did you get the upgrades from a couple or so year's ago?
  10. claud W
    So, there has not been much traffic in this forum in a while. Are all you newish owners still enjoying your stock tubes. Have you been reading all the posts in this and the Stellaris thread? Anyone beginning to roll in some different tubes? You must have learned that the 6N1P input tube is the first one you should roll because it makes the biggest difference. All tubes do not sound the same. There is a big difference between the $10 to $15 6N1P you buy on Ebay and the one that RT selects by testing 300 tubes to get 6 to 8 of them that meets the specs required and is then cyroed and pin treated.
    There is a big difference between a $40 Sylvania 5U4G rectifier and a EML big boy 5U4G for $300. Same goes for the $90 Chinese 2A3s and the very rare NOS single plate RCA 2A3s for $1600 on Ebay yesterday. That is why $600 Acme Supremes are a bargain.
    For the most part, in tubes, you usually get what you pay for.
  11. mwr2700
    The sound from stock tubes still thrills.
