DIY power conditioner?
post-1393249
Thread Starter
Post #1 of 16
MASantos
Hello,
Do you know of any DIY power conditioner/mains filtering unit?
Something which might have multiple outputs like a power strap?
THanks
Manuel
post-1393747
Post #3 of 16
Carbonman
Have a look at the Jon Risch power conditioner. There is also a company in the US that makes a conditioner based on this design. Check at AA for more details.
http://www.geocities.com/jonrisch/
post-1393840
Post #5 of 16
Garbz
I believe he was after DIY power conditioners as am I. I saw a post here on head-fi last month about a balanced power conditioner using transformers, however I have an aversion against that sort of thing. I simply don't trust my equipment to have both Live and Neutral wires on a switch. I know my gilmore amp doesn't
There have also been other relatively cheap ones involving varisters and caps.
post-1394474
Post #6 of 16
MASantos
yes, I was thinking about building one when I get my home rig after the summer, and was looking in the net for schematics, or kits.
What I need is some sort of mix between a power stripwith 4 or 6 outputs, which has some sort of filter, to clean the AC power. Also I need it to work eith 220v.
Manuel
post-1394867
Post #7 of 16
Garbz
http://www.geocities.com/jonrisch/surge.htm this one is the only one I can think of atm. There was one using transformers like I said that gave 120v + 120v instead of 240v + Neutral, but i was not interested in it so I forgot where I saw it.
post-1395010
Post #8 of 16
cetoole
Was this it?
post-1395440
Post #9 of 16
Garbz
indeed, just don't have the bling nor the patients to modify my exisitng equipment to use it.
post-1395523
Post #10 of 16
rickcr42
Are YOU talkin' to me?
Just curious but why ?
I use a DPDT switch for all my AC and the only thing NOT switched is the safety ground.This is a very common practice in high end audio.
post-1396107
Post #11 of 16
Garbz
Let me elaborate. I fully trust my high end amp, and my low end cdplayer. I do not trust my 30 year old Tuner, and I definatly do not truse my Gilmore Dynalo since I remember connecting the torroid N directly to the board
post-1398056
Post #12 of 16
pmkap
Originally Posted by cetoole
Was this it?
Cetoole - The thread you referenced is mine, the Felicia constructors thread. It only produces balanced 240VAC (120-G-120) if you feed it 240AC. If you feed it 120VAC you get out filtered, balanced 120VAC (60-V-60), with the restriction that the transformer's ratings must be halved. When fed 240vac, either balanced or hot and neutral, it will produce filtered, balanced 240AC, without the need to downrate. The thread currently recommends using 2 175va rated transformers which when fed 120vac to yeild filtered, balanced 120VAC with a maximum continuous draw of 87watts, sufficient for most individual source level components. As the recommended transformers cost $9ea and the single filtering cap $4, the cost of producing each incremental isolated,filtered and balanced ac source is about $22 + connections.
post-1398610
Post #14 of 16
Garbz
Music Fidelity use choke regulated powersupplies in their equipment. And asside from the fact I think their amps are horrible, their cheaper cdplayer is a real gem, and the choke regulating definatly works for it.
All in all I like this design and cash permitting I think i'll roll my own version of this later this year.
post-1399497
Post #15 of 16
MASantos
Are you thinking about changing the design of the schematic??
If you ever do it, please let me know, I would be defenitely interested.
Manuel
