DIY Earbuds
Dec 19, 2024 at 4:42 AM Post #4,936 of 5,016
Can you buy these just as shells or do you buy the cheapest QKZ MDR earbuds you can get and strip them?
I buy the cheapest earbud and use the shell for my build . Usualy u can get them on AliExpress around 2-3$. And the original driver is not so bad, I re use them with the cable in standard mx500 shell with a little fine tuning , and is perfect for my children, wife , friends,..
Dec 19, 2024 at 6:30 AM Post #4,937 of 5,016
Hi. Can you post a picture of how you measure your earbuds? I'm curious on how you do it. So that if it's possible, i can also compare my graph to yours :v To a certain extent of course
Yes dear :wink:
1) propped it up from behind so that it would hold the earphone quite easily;
BUT!!!
2) do not press hard, otherwise there will be a lot of bass on the FR graph(see on mesh eartips - its pinned down hard);
Need support lighter:
Dec 19, 2024 at 8:50 AM Post #4,938 of 5,016
Yes dear :wink:
BUT!!!
Thank you sir. It seems in principles, you and i measured the same way :)) I just do it without foam, to eliminate the errors or variables given by the foam+pressure applied to the earbuds while measuring
Dec 19, 2024 at 5:51 PM Post #4,939 of 5,016
Perfect, thats what I planned to do anyway. What size MMCX connector fits in that shell? Is it threaded already or do you glue a connector in?
Dec 20, 2024 at 5:46 AM Post #4,940 of 5,016
I glue in. Actualy
I usualy use this
https://a.aliexpress.com/_EG1Ko9Q but the bigger 4.8mm fits in too. You need to clear and drill the hole a little bit, and to remove the black plastic
Dec 24, 2024 at 10:30 PM Post #4,941 of 5,016
Guys, what differences does it make if i were to use these type of faceplate? Like, what's the different between them to the end sound?
Dec 25, 2024 at 2:45 AM Post #4,942 of 5,016
1) standard mx500 - wide stage, good higs and mids, fragle than black and white colors
2) fit with mx500 shells, a bit narrow soundstage, good bass and less highs(vs 1.)
3) do not fit for mx500 shell - this is for wood housing, but wery airly for sound
Dec 25, 2024 at 6:15 AM Post #4,943 of 5,016
Hey everyone!
What is a good material to make Bass tubes for buds? Plastic and/or metal.
Something that can maybe also be bent without snapping/bending so sharp that the air won't come through any more? Thinking of creating something like a bass labyrinth as @ClieOS has posted in one of his recent builds...
Thanks!
Dec 25, 2024 at 1:10 PM Post #4,944 of 5,016
Hey everyone!
Thanks!
What shell do you plan to use the bass tube for?
Dec 25, 2024 at 3:40 PM Post #4,945 of 5,016
I think I 'd start with plain old mx500...
Either trimming the fake vent away and replacing it with tube(s) or opening the vent inside towards the shell and hiding a tube inside the vent.
But basically I also want to use the tubes on other shells.
I have a few metal bell shape shells at home too. There a tube would be very short, but there might still be a usable result I hope. The rivet mod is also creating a pretty short tube.
Probably not entirely the same working principle there, but still...
Also I 'd like to have 3 or at least 2 different diameters of opening for the tubes. Thinking 1mm, 1.5mm, 2mm?
Preferably big opening - thin material - bendable without kink.
Dec 30, 2024 at 5:35 AM Post #4,946 of 5,016
Are the transparent shells more fragile than the black and white opaque shells? But that means that they have different materials?
Dec 30, 2024 at 11:40 PM Post #4,947 of 5,016
maybe added color gives a more strong plastic, but in my case all transparent shells are cracked.
Jan 7, 2025 at 7:07 AM Post #4,949 of 5,016
how do you guys organize earbuds? The tuning foam inside is so easy to get moisturize.
