MiLKMAN
- Jan 27, 2009
I have some Mogami laying around and I want to make some USB-A to microUSB cable for DAC. What good quality interconnect can You recomend?
They're splitters and sliders and yes, they're pretty common if you search those termsWhat are these two metal parts at the split in a headphone cable called? Can these be bought as easily as bare connectors?
Are you using a 3.5mm trs or trrs if you are using a trrs then tie the ring and sleeve togetherHey people, is someone able to give me some help to build my for cable for Susvaras:
4.4mm balanced plug (L+,L-,R+,R-)
What about the 3.5mm connectors? I tried + to tip and - to sleeve (ground) on both left and right and somehow the cable makes the amp clip (iDSD pro) ... original XLR cable works like a marvel.
Any tips?
May I ask where you source your wire? Always looking for new sources!Thought there might be a DIY section... Just found my way here. Howdy y'all, I'm Wolf.
Been making a few cables again this last month and was showing them off, (uber-fat 16awg litz lol) copper 4 way round braid... And they say that's very nice, could you make it more tricky somehow????
Scratches head then smoke...no there's no fire, it's an idea lol my brain almost always burns out on simple thoughts giggle, how about an 8 way 22awg litz square/box weave into 4 way round braid?
Depends on the wire I guess, some were from a couple places in the UK I think, I forget sorry. some I don't remember as I've had them for a while (I'm old retired with memory issues, and I'm a lil crazy giggle)... Last couple times I got off different vendors on AliExpress, there's all sorts there from cheap through to expensive.May I ask where you source your wire? Always looking for new sources!
