Hello all, first time poster. I've been browsing the DIY cable gallery for a bit and I'll be using the ideas there to do a detachable cable mod for my Sony V6.
I'm also trying to repair my son's HyperX Cloud I headset, left channel died completely. We're going to do a rewire of everything (except the internal left -> right audio wires). The factory cable is actually two sets of individually-insulated wires, one is 2 conductors (for mic) and the other is 3 (for audio) but both sets are then wrapped in the same insulator, much like 2 channel snake cable (Mogami 2930). At the PC end, they split into separate audio and mic connections. We need to keep that split since he uses the PC sound card for mic and a USB DAC for audio (with an A/B splitter to share signal with his Edifier dekstop speakers).
My initial thought was to use two pieces of Mogami 2893 each in 550 paracord (for looks), wrapping both in Techflex for most of the length. Two issues with that - what size Techflex would we need for two 550 paracord lines, and that seems a bit bulky to feed into the headset. Is there a better way to do that? Maybe wrap both Mogamis in a single piece of larger paracord up to the split, and then 550 to the PC end? Do we just not bother with Techflex at all?
I've seen vids of just doing a detachable cable mod for the headset using a TRRS connector, but I think that would lead to shared ground issues at the PC end of things. Any thoughts?
