DIY Cable Questions and Comments Thread
May 20, 2014 at 7:11 AM Post #1,981 of 10,181
deadofmind
  Mogami makes an ultra flex 32awg single wire coaxial construction shielded cable, it's .039" diameter and is about as small as you'll find. There is one center conductor and a shield, so 2 wires, use the center conductor as the signal, and the shield as common. Don't be fooled for that short run small 32awg is adequate. Stuff is pretty cheap, usually wire starts getting more expensive when you get this small.
http://www.markertek.com/Cables/Bulk-Wire-Cable/Bulk-Video-Cable/Mogami-Wire-Cable-Corp/W2444-00-F.xhtml
Does common mean the ground?
If so that cable might just be perfect! thanks for the info, I'm trying to do my first headphone mod ^_­^ Gonna try adding both a detachable cord and mic to my HD 280 pro Sennheisers :)
Ill buy this wire and if it doesn't work, I will probably just add dual sided connectors.
May 20, 2014 at 10:45 AM Post #1,983 of 10,181
PETEREK
Member of the Trade: ThePETEREK on Etsy
Previously known as cCasper TFG
Holland, Michigan
  HTC One M7 or M8? I have nothing to complain about my M8's camera quality.
The M7 cam quality is effing terrible. The sensors take a crap really quickly. I have one, and both my girlfriends parents do, only one of those 3 cameras isnt a POS. I had to buy a camera just so I could get some decent pictures, I couldn't with my phone. It was just getting worse and worse.
May 20, 2014 at 2:02 PM Post #1,984 of 10,181
Zashoomin
  2.1mm OD is HUGE for 22awg wire. $1.65 is steep for 22awg wire.
$1.65 a ft for OCC 22AWG Copper is not steep. I also think that this is Type 2 Litz so if you plan on using this you will need a solder pot.
May 20, 2014 at 2:17 PM Post #1,985 of 10,181
TrollDragon
Windsor, NS
Does anybody have any extras of those really skinny "Sennheiser labled plugs" that they would be willing to sell and drop in a small envelope for mailing?
I only need one and really dont want to wait 4.5 weeks to get it from lunashops.
PM me if you do, Thanks!
May 20, 2014 at 3:53 PM Post #1,986 of 10,181
Kamakahah
I hate soldering those. Got to be the worse plugs in the world. Wish I could find an alternative for them with a better soldering point configuration.
May 20, 2014 at 4:22 PM Post #1,987 of 10,181
Canadian411
Ya me too. Its very hard to solder. I find viablue is the worst plug to solder.
I made this cable yesterday and took me like 30 mins to solder, soldering area was so small I had to borrow my grand ma reading glass.
May 20, 2014 at 5:54 PM Post #1,988 of 10,181
PETEREK
Holland, Michigan
Those are really similar to the pailiccs when it comes to soldering. The ones that are the biggest pain for me are the pailiccs TRRS connectors.
May 20, 2014 at 6:47 PM Post #1,989 of 10,181
TrollDragon
Windsor, NS
Ahhhhhh and then you put heat shrink over the Viablue shell.....
Why man Why?
Heatshrink IMHO should not be seen... :)
May 20, 2014 at 9:51 PM Post #1,991 of 10,181
65535
I would use the Mogami Ultraflex for the in headband wire and use something like W2929 for the main length with connectors on both ends. That will give you 4 conductors and a shield, enough to run L/R/Com/Mic and have a shield grounded at the source.
http://www.markertek.com/Cables/Bulk-Wire-Cable/Bulk-Audio-Cable/Mogami-Wire-Cable-Corp/MG-2929-FT.xhtml
May 20, 2014 at 10:36 PM Post #1,992 of 10,181
Lohb
Surfing on electro
Anyone on here sell Kobiconn IRIS male female plugs ? I'm going to put a panel mount on my mini-amp and route it from taps connection.
Sick of XLR pendulums...so heavy....they are built like a tank but terrible when I want  to use a DAP or off of my notebook.
May 20, 2014 at 11:21 PM Post #1,993 of 10,181
Canadian411
Why man Why?
I think lot of aftermarket put heatshrink over viablue plugs. I put it there just to cover the bottom screw.
I wanted to put the black one but ran out of... so red one it is.
May 20, 2014 at 11:41 PM Post #1,995 of 10,181
paijo
hahaha...yes. viablue is hard to solder, but for tiny cable and 4 strand only, i think it's still easy to put it in... i only neds 10 minutes to put it in, the longest part is to braid the cable....:))
pailics has larger soldering area than viablue or mps eagle, the easiest jack to solder for me is rean and amphenol. soldering acrolink L shape is killing me.
Why man Why?
hahahahahha...:)).. it should be transparent heat shrink to be used, i think it will be more charming....:D
