DIY Cable Gallery!!
Dec 13, 2014 at 10:00 AM Post #14,176 of 16,054
turkeylord
Has anyone tried to re-terminate an ATH-M50x cable? Or the Chinese replacement cable?
Yep,
The wire was enameled which was kind of a pain, but a good soak in some lacquer thinner and I got it to take solder.
Dec 13, 2014 at 3:55 PM Post #14,177 of 16,054
musicinmymind
Ohh boy, I wanted to mold HD650 stock cable to have 2.5mm trrs, so that I can use it balanced with AK100 II,
I cut the wires, the there are four tiny wires inside and I am not sure how they are insulated apart. Also the 2.5 mm trrs looks so tiny, I have micro solder, even this I am not sure how to do that.
Please suggest.
Dec 13, 2014 at 5:15 PM Post #14,178 of 16,054
Hal Rockwell
Israel
Please suggest.
Green - left+
Gold - left-
Red - right+
Gold - right-
Dec 14, 2014 at 1:51 PM Post #14,180 of 16,054
020Assassin
Mine!
Mine mine mine mine mine mine mine mine mine...
If they sound as excellent as they look, I'm going to be in for a treat!
Dec 16, 2014 at 7:32 AM Post #14,183 of 16,054
rshuck
This is not directly on topic, so I can make a new thread in the main forum, but does anyone have success using the internals of the Neutrik 4 Pin male XLRs in the body of any of the other (Oyaide Focus 1/Furutech non-Carbon) shells? I don't like the design of the Neutrik connectors but it seems like nobody else makes an attractive 4-Pin.
Also, has anyone done a custom splitter to be 3D Printed? I just made one in SketchUp and sent it to Shapeways for testing. Not sure how much DIY has been done in this area, or if everyone is just using the Viablue splitters or is just using heat shrink.
Dec 16, 2014 at 9:49 AM Post #14,184 of 16,054
020Assassin
This is the gallery, there's a separate forum for questions and advice on DIY cables, here: http://www.head-fi.org/t/676402/diy-cable-questions-and-comments-thread
Dec 17, 2014 at 6:20 AM Post #14,185 of 16,054
phantomore
How much does custom cables effect your sound?
I have used them before, but only tried them on my LCD-2s, didnt seem like a huge difference to me.
Seeing that some cables are worth as much as my LCD-2s, Lol, Is it that worth it though?
Dec 21, 2014 at 9:59 AM Post #14,186 of 16,054
irgunawan
  1. MC2000 copper cable x 4
  2. Y-Splitter from rubber shield it self
  3. Cable Sleeving
  4. ShrinkTube 3-7mm
http://www.bengkelmacro.com/wp-content/uploads/2014/12/e_DSC0300.jpg
http://www.bengkelmacro.com/wp-content/uploads/2014/12/e_DSC0291.jpg
http://www.bengkelmacro.com/wp-content/uploads/2014/12/e_DSC0292.jpg
Interconnect
http://www.bengkelmacro.com/wp-content/uploads/2014/06/e_DSC9339.jpg
http://www.bengkelmacro.com/wp-content/uploads/2014/10/e_DSC9017.jpg
it using 8 strand full copper, 4 strand acrolink silver coated 0.12mm
using 3 strand full copper, 3 strand acrolink silver coated 0.3mm
http://www.bengkelmacro.com/wp-content/uploads/2014/12/e_DSC9809.jpg
8 strand acrolink silver coated cables 0.12mm full braided.
Dec 22, 2014 at 10:45 AM Post #14,188 of 16,054
rshuck
So a couple days ago I mentioned that I was getting a splitter 3D Printed by shapeways. It was the first design I made and wanted to see what type of quality I could expect. Well, today I got antsy and decided to design an XLR connector shell that should work with the Switchcraft XLR pin section from the inside. These are the renders. It's meant to have flat surfaces like you can see here. It will be unique. I am hoping the measurements I took are close enough to make this work. If not, a little modification isn't beyond the realm of possibility.
The retainer for the XLR pins is seen in here, behind that ridge.
The design is actually two pieces, the strain relief part can be removed so I can modify the opening for whatever cable diameter I want. Right now it's just a hair under 6mm for the Canare Quad. It's tough to see, but the end is slightly domed, but I wanted something that didn't have this huge ugly strain relief. After all, I'm not going to be connecting this to a microphone and run across stage. To keep this in place I will use a few set screws on the outside. I considered making a seamless design with a screw-in end, but decided against it for this revision. I ordered four plugs in total because I wanted to see what the materials actually looked like in my design. I ordered Black Detail Plastic, Polished Nickel Steel, Polished Bronze Steel, and Matte Black Steel.
This is a cap for the splitter, seen below. I wanted one made out of polished brass, and the other cap had details that were too fine for it. This was the only part of the splitter made out of Brass.
This is the body of the splitter. The hole on the left is actually the bottom of it, a 6mm hole for Canare Quad. The other holes are for the lines to go up to the ear cups and are the right size for 550 paracord. I am not sure I want to use 550, but I figured I could give it a try and see if I like it. This was ordered in Black Plastic and Stainless Steel.
Original design for the splitter cap. I knew this would be a stretch for small details. I want to see what resolution is possible, but this could only be ordered in plastic, so I did black plastic for this.
There's currently no way to retain the splitter cap. I want to try with Sugru and see if that's enough to keep it in place after building. If not a two part epoxy. If that also doesn't work, I will make a stud to screw into in future versions. In the body of the splitter there is a post opposite the 6mm hole. That's so I have some way to provide strain relief. That part is going to be improvised if it's needed.
All drawings were done in sketchup, exported with a plug-in I found somewhere to export STL files. They look perfect once uploaded to Shapeways, so hopefully they turn out with a decent quality. The parts won't be here for some time yet, but I will update once they are.
Dec 22, 2014 at 5:05 PM Post #14,190 of 16,054
rshuck
  3. Cable Sleeving
  4. ShrinkTube 3-7mm
Interconnect
Nice work on that splitter.
