DIY Cable Gallery!!
May 9, 2020 at 6:17 AM Post #15,781 of 16,147
doctorjuggles
Member of the Trade: Cable Builder
London, UK
Looks great!
May 10, 2020 at 3:47 PM Post #15,783 of 16,147
doctorjuggles
London, UK
New enthusiast here.
What are some well-tested good supplier for DIY iem cables? The 2.5/3.5/4.4 connector, and mmcx/2pin suppliers?
What country are you in, buddy?
I've made a few new cables recently which I'll share soon, but I wanted to share this one because I feel its a bit different from the norm...
Here is my modular build - the jack termination is actually a screw-on set of 2.5mm balanced/3.5mm SE/3.5mm balanced and 4.4mm balanced. No adapters needed anywhere near this baby :)
Comments and feedback welcome
May 13, 2020 at 12:13 PM Post #15,784 of 16,147
MightBeAlon
Member of the Trade: nlovell audio
England
I think this is one of my favourite DIY cables, colour-wise. It doesn't match with anything I own, but I really like how this one came out
May 13, 2020 at 12:22 PM Post #15,786 of 16,147
MightBeAlon
England
In terms of raw material suppliers (wire, Y-split, mmcx/2pin, 2.5/3.5/4.4 jack) which ones are good on taobao / aliexpress ?
QYFANG have some great options for both Y-splits and source terminations, they're worth checking out at least.
May 13, 2020 at 12:44 PM Post #15,787 of 16,147
Eddie C
Calgary, AB Canada
WIRE
I buy the braided sections from aliexpress Electro Acousti: refer to my post HERE
You can buy length by selecting quantity x length and it come in a long continuous section. Saves time on braiding process, and cheap when you consider you are getting 4/8 wires per length (for example 1ft of 4 wires = 4 ft of wire)
2 Pin Connectors
Bought mine from here: https://www.ebay.ca/itm/10set-20pcs...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
Plugs
I have been buying plugs from this seller: https://www.ebay.ca/itm/20pcs-Stere...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
May 21, 2020 at 3:39 PM Post #15,789 of 16,147
legopart
Create some adapter for my old amp XLR4pin-> TRS (from quality RCA Cable)
the secend is TRS extender.
unfortunately I had only 4pole connector, so I used it and short the the top 2 pins
made from broken USB IPAD charging cable (+-5V is for GND and DATA+ DATA- for R+ L+).
gbPehRK.jpg-18b9422c2169
May 22, 2020 at 11:59 AM Post #15,791 of 16,147
legopart
Converted an over ear set to downward wearing.
What connection do you use for this headphones connector?
, I want to make one too for my IEMs
May 22, 2020 at 12:08 PM Post #15,792 of 16,147
assassin10000
CA
May 23, 2020 at 12:22 PM Post #15,793 of 16,147
tranhieu
Member of the Trade: DIY Amp Builder - AKA kytuphicanh
Caution: Incomplete Sales
I haven’t built a HD580/HD600/HD650 cable for like 8-9 years. Due to the need for a high impedance ‘phones for trial with the forthcoming OTL tube amp, I grabbed a pair of HD58X and built a balanced cable too. So far so good out of my balanced Dynalo-Dynahi.
