distortion with volume
Apr 30, 2009 at 7:30 AM Thread Starter Post #1 of 4
erfmd
I am using singlepower mpx3 amp with 701's and dh5000 and high quality cd player as source (analog input to amp no DAC) and get considerable sound distortion at higher volumes - minimal at lower volumes. What is the most likely reason or am I simply listening too loud? Would a DAC help? It is a high quality cd player ($1000 several years ago) so presumably has a relatively decent built in DAC.
Apr 30, 2009 at 5:31 PM Post #3 of 4
Is it the same magnitude on both headphones ?
Is it the same magnitude (as far as you can tell) on all recordings ?
What music do you listen to , massed voices for isnatnce often sound distorted
Just how loud are you playing it - all headphones have a maximum input power and your amp will exceed that for the 701s
At lower levels (with the above provisos) distortion and noise should not be
audible, if you are *routinely* getting distortion something is wrong especially if it is the same on both headphones (notwithstanding overdriving them) . To discover where the blame lies you need to swap things out one at a time.
You need to borrow (a) a different CD player and (b) a different amp and (c) some really good quality recordings to rule out your music choices - sorry but it has to be asked.
Good luck
