Dusty Chalk
Head-Fi-holic: With headphones would just be a benny.
- Jun 22, 2001
Originally posted by Orpheus oh, by the way, rick, it doesn't matter what aes/ebu cable you get. as long as they meet the standards posted by the aes/ebu commitee, any cable, no matter the price, will conduct perfect digital transfer to any component. this is assuming that you have a normal electrical environment. if you were to have many cables, and we're talking much much much more than a home system would ever have, electromagnetic interference may become an issue. also, if your cable run is much longer than say 20ft (i'm not sure what the posted aes/ebu standard is)... then signal degredation might make a difference too. but like i said, in a normal audiophile/home studio environment, you do not have any of these issues. thus, any cable will do. .......and i know there are plenty of people that think that expensive spdif/toslink/aesebu cables make a difference. they absolutely do not. i can prove it to you if you wish. use any cd player with a digital output... then take a cable and connect to a a good pro computer interface. then record to 2-track. make sure to have your program start automatic recording when a signal is detected.... most pro software will do this. do this for as many cables as you wish. now, use a byte by byte comparison program to compare each audio file to each other. if given that the recording started at exactly the same time for each cable.... EVERY file will be identical up to the shortest recording's ending. don't bother saying that your ears can hear the difference until you do the experiment. if the files are identical, then clearly there never was any difference! dean |
