chris75
- Sep 3, 2004
Hi,
I´m thinking about buying a Sennheiser HD-580. I tried that headphone on a shop, but there was just the demonstration model, which already looked a little bit worn. So I searched on some online-shops for the HD-580 and found two different versions, the "HD 580-1" and the "HD 580-II Precision". The latter one seems to be a little bit more expensive. I ´couldn´t see any optical difference between this two. Is there any difference? I even don´t know, which version I´ve tried on the shop. Which one I should order?
Thanks for any help,
Chris
Chris
