stevenb
- Dec 26, 2001
In another forum I asked which phones + amp combo to use with an iPod. The response was that you can't use an amp because it has no "line out". I thought a line out was just your normal 'pones connection with a fixed volume (i've even got this nifty "portable" record player from Sony which must be 10 years old, and in the manual it says that you have to put the output volume between 3 and 5 when you connect it to the AUX input of an amp)
Also, is it possible to put a crosfeed between iPod and ER-6?
Stevenb
Stevenb
