noplsestar
I was asking around if it makes sense. Seems like it doesn’t make senseI saw some where abt opamp swapping, was it in few pages back? or at FB?
I have tried and found it quite easy to disassemble the opaAfaik, the soldering of the opamps is so tight that switching them is a high risk operation, even for skilled people. Or maybe is the whole amp structure that makes the manipulation complicated. I might be wrong, though, but I remember having read something about that earlier in the thread
More to come, but I thought I'd give a quick update on the noise floor of this amplifier with a couple monitors:
This is an incredibly powerful amp - and I'm surprised there isn't more hiss. I wish it had 1/3rd the power, or that Anson Tse made a class A amp specifically for sensitive in ears. Even in low gain, I can't get much travel on the volume pot before it's too loud. So I have to lower the voltage coming from my DAP's line out.
- Moondrop Starfield is pretty much silent until you turn the volume past the halfway point. Even then it's a very faint waterfall hiss and a non-issue when music is playing.
- Custom Art Fibae 7 CIEM - there is a faint waterfall hiss even at lowest volumes, but it is completely acceptable to me (and I despise hiss). Once music starts playing it is a non-issue. Turning the volume pot doesn't seem to bring on much more noise, perhaps a tiny bit more.
Aside from too much power for my use case, the sonic performance excellent. Nice injection of overall class A warmth and refinement/airiness (as if someone put an indiscernible amount of 'hall reverb' on as an effect - clearly there is no additional reverb, but it just gives that 'sense' and I'm not sure how else to describe it). Compared to DX220 amp1ii 3.5mm PO, there is a richness to it that emotionally envelops the listener. The bass becomes a good bit more weighty and lingers a tad longer (just a touch, but not slow at all). Midrange instrument separation seems to go up a notch. Treble sounds more 'wet' and 'sweet', not quite as dry as a reference amp (with reverb tails being extended a touch). By no means is any detail given up. I seem to be able to listen slightly louder than I normally do because of how 'clean' the sound is. It's not 'crunchy' like ibasso amp7 is, for example.
I noticed the sound improvements with both DD and BA monitors and would argue that each of them benefitted as much as the other. I just like the sound of this amp!
I've only spent one night with it and two IEMs. I'll have more to test with it: Blon BL03 and Oriveti OH500 are on the way. I can at least test the noise levels for them and will report back soon.
yeah, I'm not sure why this amp hasn't gained more traction. To me, it sounds like the slight coloration/euphony "refinement" that people throw thousands of dollars at.
Perhaps it's the insane power? That's my only quibble with it. But I know that's usually a selling point, so I remain confused.
Why not just buy it here?One thing that jumped out at me: someone shopping for a portable HP amp (a subset of a subset) will be presented with many $25-$100 options when shopping on the HA-2 Amazon page. Class A and Dethonray mean nothing to most of those folk. What has meaning? There is only one review. As a shopper, would one think it is worth the extra 200-800%?
I was shopping specifically for the HA-2; if I wasn’t I would have likely thought it was overpriced. I think it is a delightful unit. Too bad, really.
https://penonaudio.com/dethonray-hpamp-ha-2.html
Of course if you have had some portable high end amps, you know that the HA-2 is very reasonable priced for what you get. As stated a few pages back, I had the VorzAMP Duo II for about 700 Euros. And it sounded not as good as the HA-2.
Thanks, but DC01 only have 2.5mm balanced outHi hongky. If I understand your question, you are looking for a DAC with USB-C input and line out. There are a few. One I know of at the top of my head is the iBasso DC01. (Click on the link) My phone doesn’t have USB-C so I haven’t use it but iBasso does good work in their niche.
Most dongles I have used need your phone volume at 100%, if the level is not greyed out), which they equate to a line-out signal. Some back and forth about whether this is actually a line-out but, anyway, it is a good prospect.
DC02 in that caseThanks, but DC01 only have 2.5mm balanced out
