Dethonray Dtr1 Prelude high resolution player
post-15253380
Post #781 of 1,145
golov17
Russia, Bashkortostan, Kumertau
Age
50
post-15253398
Post #783 of 1,145
golov17
Age
50
Hi there,
is there a way how to resurrect my frozen DTR1? I tried each and every button combination but nothing works. I’m on FW 2.20.
Have you connected the charger? Did you try to press the reset button with a paper clip?
Reactions: Klonatans
post-15253401
Post #784 of 1,145
lithrai
ive installed the 3.0, thanks @golov17, which was pretty seamless. i then turned if off and it wont switch on again, any suggestions gratefully received :)
Next to 3.5 mm earphone output is a reset hole. Try to use sim card pin tool or something similar.
post-15253437
Post #785 of 1,145
teknorob23
UK
UK
Website
www.springloadedfilms.com
Reset paper clip worked, thank you :)
Only problem i have now is since installing the new firmware my SD card has become unreadable on my mac and i cant first aid it, or erase and start again "file system has left marked as dirty"
post-15253785
Post #789 of 1,145
lithrai
MicroSD card is formatted to exFAT. I don't know how to format to FAT32. I have only two options, exFAT or NTFS.
post-15253800
Post #791 of 1,145
golov17
Age
50
post-15253886
Post #793 of 1,145
Cat Music
Miau
Miau
Mine arrived today - aI am just starting to put it through its paces, but so far, it is soounding quite impressive. Took a moment to reset the language to English, as I do not read Chinese......
Have a 400G Sandisk card in there, loaded with wav files (I pulled it from the QA361, so I'd have the same music to reference. So far I have used my Sennheiser IE800s, Campfire Solaris, (walk and coffee shop), and at home tried my Final Audio Pandora Hope VI, Focal Utopias, and a quick listen with my Nordost Heimdall 2 wired Meze Empyreans.
The DTR1 drives them all, clearly shows their differences, seems equally at home with each of them. More to follow as I live with it for a few days. No regrrets so far- this thing is what Mim said it is.
Which one is better for you the QA361 or the DTr1 in sound quality?
post-15253937
Post #795 of 1,145
fzman
Member of the Trade: Music Direct
I think they are equally good, but sound a bit different. I have not done a direct comparison between them in quite some time. The DTR1 is smaller, perhaps a bit more open sounding. Both are hard to see in direct sunlight, but are quite portable. I have a bunch of portable players, and use them exclusively for portability, so often use ones with daylight-readable screens for taking on walks (big part of my overall music listening)
Reactions: Cat Music
Users Who Are Viewing This Thread (Users: 2, Guests: 1)
