Dethonray Dtr1 Prelude high resolution player
Discussion in 'Portable Source Gear' started by jaykay1967, Jan 25, 2019.
17 18 19 20 21 22 23 24 25 26
28 29 30 31 32 33 34 35 36 37
  1. Wiljen
    Has anybody seen an option to purchase a 2nd charger? I agree that the DTR1 charging system is a good one, but I can see a need to have one at home and a spare at the office. A vehicle charger should also be possible as the 12V auto system has enough current to support conversion to the needed 8.6V at 600mA.
  2. CactusPete23
    Dethonray folks told me that they would have some spare chargers available in the July/August time frame.
    A car charger is a good idea. Don't think they thought of that yet, so none in the pipeline.
    Palash likes this.
  3. ehjie
    You mean in the Fullness, body of imaging? or in the Detail retrieval?
  4. someyoungguy
    Saw the review on the front page of head-fi and ended up here. A few questions:
    1. Is there a button lock, so you don’t accidentally push buttons while it’s in your pocket? If not, have people had any problems with accidental track/volume changes on the go?
    2. What’s the current status of the case? Not available?
    Thanks
  5. F700
    No button lock afaik. The volume button must be pressed harder than other DAPs, so no problem with it on the go I assume.
    Case is coming, in 2 months approx
    someyoungguy likes this.
  6. Palash
    My friend told me his DTR1 not entering in update screen and after a long conversation its turned out that he is holding power button and volume down button instead of front down key.
  7. toranku
    I'm getting one to pair with the modded FD01 :wink:
    cocolinho likes this.
  8. Wiljen
    I found the update function to be pretty finicky about cards. I finally found that a 32gb formatted Fat32 worked, anything over 64 would not regardless of format type. Don't get me wrong, it is using my 400 for music now without a hiccup, but for firmware updates a smaller card seems to behave better. I spoke with Anson about it and was told that it had to be Fat32 formatted and after what I found it looks like the block size needs to be 512 bytes (64gb down should default to this).
    buonassi likes this.
  9. Palash
    With my both 64 gb card and 128 gb card formatted Fat32 worked fine while updating.
  10. jemuelvellejo
    How's zx300 compared with dtr1? Been thinking of selling my zx300 and shozy-aaw pentacle iem to get this dap. Hopefully i am not in the wrong direction.
  11. terry1109
    U are definitely in the right direction.
    Dtr1 is leagues above zx300, as long you can can stand button control rather than touch screen.
    But what iem u have to pair with dtr1?
    In my opinion, the pentacle will definitely not match with dtr1, as i tried it on high output player such as alien+.
    jemuelvellejo and F700 like this.
  12. duncan21
    They are not comparable in SQ. If you feel comfortable to give up touch interface/ Bluetooth/ long battery life, I think you are on the right track.
    F700 likes this.
  13. Sonic Defender Contributor
    This sounds like an amazing sounding player, so glad to hear of a pure audio-quality focused player, but for me Bluetooth and some useful advanced features are important. I wish I needed another player, but sadly that isn't the case or I would certainly try this. Been fun reading this thread.
  14. toranku
    Ok I just received my DTR1. Big problem - it's way too powerful at volume 1. I am apparently on firmware 2.0. Have to use a earbuddy/iematch.
  15. F700
    Firmware 1.44 fixed that. Do you have a fw 2.0? Do you have a link for it?
