More detailed system stats:
Case: Silverstone TJ-06 w/ window
CPU Fan: Zalman 9500 CU LED
Fan controller: ? run on minimum voltage before fans cut out.
Originally Posted by Gautama /img/forum/go_quote.gif
Replace case fans with Yate Loon's.
Replace 7800gt fans' with third party fans
Replace CPU fan with Arctic Freezer 64 Pro
If you can hear your HDD suspend it somehow, I have mine lifted up on the base of my case by a roll of foam sheets.
I am going to find about re-mounting my HDD's but my CPU fan is better than than..i think... Zalman 9500 (huge round one 92mm, first one), and for the fans...I have to find them...and I agree with the 7800gt fan replacement...Your probally the one I agree the most with.
Originally Posted by Bizzel /img/forum/go_quote.gif
You can buy little rubber mountings for your hard drive that sit between the metal casing and the drive exterior. They work nicely for reducing the vibrations and I think you can get similar things for case fans too that fit in place of screws.
Cant buy rubber mountings...case doesnt let me
Originally Posted by mojo /img/forum/go_quote.gif
Your system is not that beefy. Check out some of the systems on the Silent PC Review forums.
If you get the right case and a good CPU cooler like the Sythe Ninja, cooling your system quietly should not be a problem. The only real issue is the two graphics cards. There are plenty of suitable coolers out there, the hard part is making two of them fit.
Alright...My system is beefy...I know there are lots of systems out there and Ive build a few being only till 2 months ago a technician at Canada Computers (local computer store). My system is easily classified as being beefy even if yous state there are better ones...and wouldnt adding more coolers make it noiser?...and stated above...the CPU cooler thingy...I have a zalman 9500...not looking to swap...
Originally Posted by xinoxide /img/forum/go_quote.gif
heh.
i wish thats all i could say. but that would be a total waste of a post.
and grats on going for nvidias SILLY mode. you got like what... 20% performance increase, bet you dont even have a monitor to support resolutions for it to even matter. and look what you got, a whole lot of noise. silly boy!
ive been bluilding completely fanless systems for years now. the idea is that heat rises, even if there isnt much of it. also, aluminum cases are amazing for cooling things such as hard disks. (thermal paste the sides, also kills vibration noise)
your athlon will run cool enough as it is. if you applied the thermal paste right( you can visit the softhardware.netforums, they have a noob-proof tutorial for correctly applying thermal paste.) you shouldnt really need a fan on a decent heatsink when running stock speeds, but maybe a larger size standing heatsink, they tend to work rather well in silent setups.
maybe one large fan in the top if you think airflow needs some assistance without upgrading cases.
as for the videocards, thats your fault, sell them then invest the sale of those 2 cards into getting a quieter videocard with a wide memory bus and high memory clocks, frame buffering benefits mostly from this (means steady framerate, wont get the jitters of silly mode trying to sync rendering, EVEN THOUGH, silly mode has a higher average of frames per second).
LOL....Have you used 2x 7800gts with newer firmwares?...it works fine...beats my friends crossfire system...and clearly you are hating the nvidea...so im not going to waste my time taking advice on those GPU suggestions because we have a difference of opinions.
As for the thermal paste...I know how to apply it...so dont worry about that...I also dont use cheap crap for it either...and I also lapped my heatsink...so again....dont worry about how i apply my product...I am A+ certified with 5yrs personal experience and 1yr corperate experience in system building.
hopefully I only offended a few people...lol...jk
So...Its hopefully going to work out like this:
1) explore my existing case for mounting alternatives
2) Purchase alternate fans (case fans, and GPU, PSU is still under warrenty, and CPU is top of the line zalman minus a generation that supports am2)
3) Seek some sound deadening material from somewhere.
4) If all else fails...throw PC out of window and buy a new one...
