rudra
@PitBul34 the usb connection in DAC68 bus powered or supplied from internal power supply.
the DAC8pro2 has an I2S input in HDMI connection..does anybody know if it is PS Audio pin-compatible? (like the new Matrix pro and, alas, unlike my Gustard X-20).. I tried the website with google translate and couldn't find mention of it.
thia could be a game changer for me.
I'll be using it via I2S input through a Singxer SU-1. I'll let you know what they inform me with in terms of pin configuration.
anyway..I just so dig the name--"Denafrips"..how the chinese come up with this stuff?
I have a Denafrips..oh , really? cool, does it work better than the Vitamix?
@Energy what level is you holo dac.
Ares and DAC68 uses the same resistors, as i know (~ 250 pcs per 1x R2R Ladder)
http://www.denafrips.com/store/p1/DAC-68_R2R_.html
I am currently using Audio Gd DAC 19th 10th anniversary version based on 2 x PCM1704UK.. I wonder will these DACs an upgrade ?
I've had Level 1 & 2. Have tried Level 3 next to them as well. They all sound pretty much the same with the Level 3 "KTE" being a tad quicker in transients and more microdetail, but very subtle.
I honestly could not tell a difference between Level 1 & Level 2. After they've burned in, they sound exactly the same. This is just from my perspective though. Take it how you may.
