Knee Deep In Epoxy
Hey, I had similar issues (though not exactly the same) on my desktop PC. I reinstalled the USB drivers for my motherboard and this resolved the issue.
On another note, if anyone has issues on Windows 10 finding the "USB HiRes Audio F-20 Configuration" device in Device Manager, mine didn't show up under "Other Devices", it showed up under "libusb-win32 devices" instead. Hope this saves you some time, because I kept thinking that my Ares II wasn't going into programmable mode when I put it into standby mode and pressing the Phase button.
Cheers
Rip
Thanks for this. I've actually sent my device to my local retailer as that is what was recommended to me by Vinshine. I guess I'll find out once they've had a look at it what they think is wrong with it, thanks for taking the time.
I am curious to hear from those here that have done the FPGA update whether they experienced any sound quality issues after the update? My device developed a static popping sound, which I could hear both before my USB connection died, but also when I connected via optical after the USB issue started. it could be that the problem was due to the USB in any case. Even though the USB input was tecnhically not in use when I tested the device through optical after the FPGA update, the faulty USB section was still physically part of the device so may have been interfering with the audio of the whole device.
so I'm wondering whether anyone else frequent experienced static popping after the FPGA update?
