Dekoni Audio Releases True Wireless IEM Tips
Sep 28, 2019 at 5:36 PM Thread Starter Post #1 of 4
Bergenfield, NJ
Dekoni Audio is pleased to announce a new version of our ear tip replacements, the TWS Bulletz for True Wireless IEMs!
7ApBy4Z9AWkWReRWBsN9mNLL_EsBXOqWhBYOp2Q6Y7AcHB3JRVHxC7b2-H1EsITUF8DCump6ke0jJCiC8XGZeYvmSuxkXkg6hbHuZo6SnllywiA6SkRf5DKpYhgLj_FKNyB2OQNG
Have you been seeking the perfect everyday earphones that you can always have with you, purchased some fancy True Wireless In Ear Monitors (TW IEMs) with no cable, only to find it difficult to close the case’s lid when storing them? Have you wanted to try Memory Foam 3rd party tips, but discovered that most tips are just too long and cause the ear piece to not charge reliably? Well, no longer do you have to choose between comfortable fit and fitting in the case, with Dekoni’s new shorter-length TWS Bullets!
The Bulletz series was released in 2017 as an answer to non silicone ear tips having no way to safely be cleaned. All of our memory foam ear tips are washable with cold soap and water. Dry with a paper towel and they’re as good as new! The TWS thread size is the same 4.9mm bore diameter as our Mercury Bulletz, fitting many models such as the Sennheiser Momentums, Fostex TM2, and most others. If you have felt that regular tips inserted into your ears too deep or changed the sound too much, TWS tips can also be used with all the same IEMs as our Mercury series!
5zt1UR9D74--U-7Hs-8e9Yi1cjg8WLciGLF4y-iXnUziq0hq6rgFBDzlAflQfp_dxz7m_7VmxNhfqRKDCG6svhui7yrJ1fGZnnv7EVbGucXLJ6GBxYp8RYBDDkFbzlClc3ZyioWI
RyKW1WEVDB4tlB8uual3ligrvqoA9de4wf5JIyukL0KKxclD1cGamrSnKUZAuOZxU2F5NTkmsFbnjJlEGu_dPCguQolLQnZNNB37wBiRgmh1n-a-uYHsSSvuKFnNJ6XavlXTFpvc
Distinguishable on store shelves from our “Dekoni Blue” regular Bulletz, the TWS Bulletz are packaged in a mainly white blister pack. With six tips in small, medium, or large sizes, the TWS Bulletz sell for $19.99
U2YAEicefR_wKe6GPTxLUUmBhe1UD8zuYQWBqDfY-A2Wh3pLiqmBV1fum9YK3tec-3oKt1ZUyp-WwVEh7fWW1UyqBq631_bJLVkMZTqjSFcC9HVCvJc-6xaBTWBhvArmKL4pt2Fy
sales@dekoniaudio.com | dekoniaudio.com | facebook.com/dekoniaudio | instagram: @dekoniaudio.com
Dekoni Audio Stay updated on Dekoni Audio at their sponsor profile on Head-Fi.
Dekoni Audio @dekoniaudio http://www.dekoniaudio.com sales@dekoniaudio.com
