dCS Bartok
May 24, 2022 at 9:57 PM Post #1,516 of 2,027
The amp section on the Lina Amp is obviously more complicated than the one on Bartok. dCS is also using their proprietary blue box power solution for the entire Lina stack. It gives the best of both worlds of lps and switching power. Whereas the power for the Bartok amp section is a Toroidal Transformer Coil.
May 24, 2022 at 10:15 PM Post #1,517 of 2,027
I'm sure someone will do a comparison with the Bartok someday, using the Lina amp through Bartok lineout and the Bartok HPA. I'd be curious.
May 27, 2022 at 2:16 PM Post #1,519 of 2,027
Is 10.000€ for a mint Bartok without HP, 10 month old, a good deal?
I'd say yes. It costs double of that new.
Bartok received a huge price increase recently. (From 14 to 20k)
May 27, 2022 at 2:36 PM Post #1,521 of 2,027
And what do you all expect from the update at then end of the month?
Isn't that an update any dealer could do for you, even wirh the used Bartok?
May 27, 2022 at 4:17 PM Post #1,522 of 2,027
Yes. It is a software update that is supposed to provide improvements in SQ as well.
May 27, 2022 at 4:41 PM Post #1,523 of 2,027
I wonder if the massive price increase(s) on the bartok were not so much related to increasing material costs, but to make room for the new Lina:thinking:
May 27, 2022 at 4:47 PM Post #1,524 of 2,027
You mean so that the Lina DAC can sit at 14k?
May 27, 2022 at 5:30 PM Post #1,525 of 2,027
Very likely. When you are dealing with boutique hifi products that's $10k+, your BOM is not all that relevant. You are essentially paying for R&D, extra labor (mostly case work), lack of economies of scale and brand. I am sure dCS is NOT pricing their products based on cost plus model.
May 27, 2022 at 8:54 PM Post #1,526 of 2,027
May 27, 2022 at 9:22 PM Post #1,528 of 2,027
You can do the update at home by downloading the new software.
Yes..you can access Bartok from web browser in the same network. Just type the ip address and you are into it.
May 28, 2022 at 3:05 AM Post #1,529 of 2,027
May 28, 2022 at 4:26 AM Post #1,530 of 2,027
And is the Lina dac to be expected to sound similar to the Bartok? I do not care too much about the form factor or the touch panel of the Lina.
