DC/DC converter to power tube amp?
post-1443408
Thread Starter
Post #1 of 4
KTpG
I found this DC/DC converter (may need to scroll down some) and was wondering if it would adequately drive a tube headphone amp. It states that it will take 12V, 3A input and produce +/-100V at what I guess would be 150-180mA or so.
It looks interesting, if its specs are decent enough for audio. Using this could make a decent portable tube amp, which could be powered by a wallwart at home or cigarette jack in the car. What do you all think?
Thanks
post-1443767
Post #2 of 4
nikongod
DIY-ku
i think that those are ment more for powering small electro-luminescent films.
for a tube amp, you may like the results of getting a 12V-120vac inverter, and then running whatever power transformer you want.
alternately, a hybrid amp with low voltage tubes may suit you.
there are a fiew portable low-voltage tube amps available if you look about.
post-1444368
Post #3 of 4
kevin gilmore
Señor Stax. Señor MAXX.
Can Jam '10 Organizer
For that price it would be impossible to build something with enough
power to do a tube amp. There are switchers that do this, but you
are looking at more like $500 and up.
post-1446807
Post #4 of 4
nikongod
DIY-ku
why not use a 12vdc-->120vac power inverter into a normal tube power transformer?
a 600W power inverter is like $50 on ebay. you can easily get away with less if you run the tube heaters straight off of the 12V supoly of the car. maybee with a regulator if necessary for voltage....
