darkvoice speakers?
Aug 31, 2018 at 10:28 PM Post #16 of 20
You would run your set-up this way
Modi>Darkvoice>new amp
Use RCA cables from the output of the Darkvoice into the new amp,which means your Darkvoice will need to be powered up to pass thru a signal( I believe) and it will act as a tube buffer.
An alternative is to get a Y splitter cable and run separate RCA cables out from the Schiit DAC,one pair into the Darkvoice and then another pair of RCAs into your speaker amp. You will lose the tube buffer aspect of the Darkvoice,but you wont go thru tubes nearly as quickly.
A 3rd option as I mentioned prior is to skip the new amp and just buy powered monitors,which will then run straight out from the Darkvoice.
Aug 31, 2018 at 11:08 PM Post #17 of 20
If I Buy the
Dayton Audio DTA-120BT Class D Mini Amplifier 60 WPC with Bluetooth and Power Supply
how would i connect to my darkvoice?
Run an RCA cable from the Darkvoice's line-output (RCA), to the line-input (RCA), on the DTA-120BT.
Sep 1, 2018 at 1:26 PM Post #20 of 20
The Sys is just a great little piece of gear so handy and versatile.
