Fitz
- Nov 12, 2005
It's been out a while.
I imagine it would be quite a pain to match volumes if they're using the same kind as the 336 (a linear pot), since they have barely any movement between soft and loud, but with a pair of decent log taper pots (in a pair of 336is running dual mono) I had no trouble keeping the channels matched. Usually it only took me one or two fine adjustments after making any significant volume change.
Originally Posted by M0T0XGUY /img/forum/go_quote.gif When did this come out? I don't remember seeing any threads about a new Darkvoice. EDIT: Just curious, but does the amp use a stepped attenuator? If not, then how do you keep the left and right sides equal, I imagine you could drive yourself crazy trying to get them to sound the same. |
