Darkvoice 336i & 336SE Tuberolling PartII
Discussion in 'Headphone Amps (full-size)' started by heatfan12, Jul 31, 2008.
155 156 157 158 159 160 161 162 163 164
166 167 168 169 170 171 172 173 174 175
  1. JKDJedi
    You don't need a pair. And 2550/2550 is right of the assembly line spanking brand new... 600/2550 is used and abused.. but still might last you a few years. My 2 cents. :)
    This might work out for you...
    https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/233354237912
    And wow did a quick ebay search of New England...them tubes out there are pricey! Get this one and it will be your end game tube...
    https://www.ebay.co.uk/itm/Brimar-6...055674&hash=item28853d1bf8:g:KfgAAOSwRmhdgTVV
  2. Taffy the tramp
    Thank no post to uk but Grrrreeeaaat info many thanks your to kind my friend
  3. Taffy the tramp
    Sorry premature eclickulation clicked wrong 1 my bad
  4. Taffy the tramp
    WOW £100.00 bucks for a little valve .what makes it THAT good ,I know YOU know what your talking about .
    just imagine your talking to valve dummy Duu you are ,its a f*** mine field different codes , age manufactures and countries and silly buggers buying other people's valves and stamping THEIR NAME on it or have I missed anything
  5. Taffy the tramp
    I've tried to stop the sale of the Tung sol 6SN7GTB he wont budge unfortunately I'm stuck with them sooo I'll try them I think I'm not sure what to do ? I'll have to think about it for a while
    Thanks again all for invaluable knowledge & information gleaned over many years & at great cost
  6. Taffy the tramp
  7. Taffy the tramp
    Thanks I would have bitten ,them number mean nothing to me ,many thanks
  8. cddc
    if 600 is mu, it's basically garbage, 2600 is close to new. You can post links here and we can see if it's a good buy.
  9. cddc
    tubes normally can last 5k hrs, some military spec or premium spec tubes can last 10k hrs
    Jedi's Gold Brand Sylvania 6080 is rated for 10k hrs, i believe
  10. Slade01
    Keep in mind those measurement readings are specific to that machine tester (e.g. Hickok 539, etc.) . Other times you will see other ebayers give measurements such as 81/79, which obviously seems super low, but for that kind of tester (a tube tested on a TV-7 tester), this is how it reads out, and that range 81/79 would equal a strong rated tube. But yeah, feel free to post links here and im sure you'll get feedback.
  11. Taffy the tramp
    This is from the same seller as the tung sol 6SN7GTB s-l500 (25).jpg s-l500 (26).jpg
  12. Taffy the tramp
  13. Taffy the tramp
    Ok thanks again those valves we do me
  14. cddc
    Brimar is pretty good, I have one with clear glass instead of black glass...GEC is even better... actually all British valves are very expensive
    JKDJedi likes this.
  15. Taffy the tramp
    I ment the £100 one you linked me
