Darkvoice 336i & 336SE Tuberolling PartII
Discussion in 'Headphone Amps (full-size)' started by heatfan12, Jul 31, 2008.
90 91 92 93 94 95 96 97 98 99
101 102 103 104 105 106 107 108 109 110
  1. bluzeboy
    i really was wondering which slot contains the power tube and which is the power tube?
  2. Jim Spec
    I believe I had the front and back reversed. Don't know what I was thinking. Sorry, JS
  3. dobigstuff
    bluzeboy:
    The 6AS7 is the Power Tube. You can also use 7236, 5998 and the 421A.
  4. spacequeen7
    Picked this up today ,hope they worth it
    I have few TS and Cetron 7236 almost identical but I've never seen 421A
    [​IMG]
  5. Gallic Dweller
    Combien/quanto/how much?
  6. spacequeen7
    too much ..haha
  7. Oskari
    spacequeen7 likes this.
  8. spacequeen7
    Thank you Sir ,I bought from him in the past (few tubes for BH Crack) and was satisfied ,I didn't payed the amount his asking for and offer the amount I would pay for a pair of NOS TS 7236 or NOS Sylvania 7236 ,visually tubes look very good ,especially pins
    I'm pretty sure he will take returns if I wasn't satisfied
  9. Oskari
    I'm not going to push this. You should do your own research.
  10. spacequeen7
    Here is little update on that controversial "421A TS",just visual comparison between "421a" (Left) and 7236 Cetron/TS (Right)
    [​IMG]
    [​IMG]
  11. Gallic Dweller
    They are the same but I'll bet the price wasn't.
  12. Gallic Dweller
    Driver tube - I havn't seen anyone mention the Russian mil. spec. - 1578. I have 2 pre-amp driver tubes that are end game for me. The musical/emotional Tung Sol 6F8G RP, older version of the TS 6SN7 RP (some say, just a touch better). Then there is the 1578 - where the TS has wonderful warmth and musical detail, the 1578 is very transparent, detailed with great depth and a top end that goes on and on without a trace of harshness. In no way is it analytical.just very detailed and open. I use the TS 6F8G as driver and 2 1578 as o/put tubes in a hybrid head and power amp. This combo for me is end game, the two compliment each other so beautifully. I have used 3 x TS 6F8G for an overpowering emotional experience. Sadly neither of these tubes have been cheap for a long time.
    Mostly the 1578 are sold out of Eastern Europe or the Russian Federation and sold in pairs or quads. Be VERY CAREFUL - if you can't see the multi-holed plates, they are a con. As pairs they normally sell @ $150. @$75 a tube they are up there with the best. At the moment I'm using one of these with a bog standard GE 6AS7GA. This o/put tube allows the character of the driver tube to shine on through. Many say the o/put tube dominates, this was so for me when I used a Svetlana which was too soft and creamy but the GE let's me hear the TS and the Russian.
    I don't think that $75 is too much if you pair the Russian with something that may add a touch of warmth, certainly this is a sparkling open tube. If the Beyers could emulate the top end of the 1578, they would be no contest h/phones.
  13. spacequeen7
    They are not the same and they do sound different :)..it's like switching from 60Hz to 144 hz monitor for gaming haha..it will give you brain freeze listening to music
  14. Gallic Dweller
    The Siemens C3G is that a drop in with adaptor for the driver slot ? I hav'nt looked at the specs yet. Also there's 3 different labelled Tung Sol 7236 on Ebay, lots of them - just what relevance/differences do these white/black and red laberls represent?
  15. mindhead1
    I have the 6xx and was not impressed with them until I plugged them into the DV336SE. I agree that the stock tubes are not terrible. I updated my tubes with an RCA NOS-6AS7G and a Tung-Sol 6SN7GTB and the difference over stock tubes was noticeable. I attribute most of the change to the RCA 6AS7G. It really widened the sound stage, clarity and low end punch of the DV336SE. For me the DV336SE -> 6xx combo is an ideal match and all I have been listening to for the past 4 weeks. I have been considering picking up a set of DT880 or DT990 to use with the DV336SE, but need to ease up on the headphone/tubes/amp spend for while.
