richard51
- Jul 21, 2013
I have been sorbing my two main speaker set-ups for some time now and this gives a big boost in clarity even though the big Polks are spiked and the smaller Spicas are fastened directly to the wall. The ideal would be to sorb the insides of the speakers, but I have no intention of opening them up. I have had good luck with sorb on the speaker front but yours look too fancy to want to glue sorb to the woof veneer. Mine do not have that type of veneer and are then covered by grills so you would not know what I have done by looking. The main problem I have had sorbing speakers is finding the right glue. The 3M 80 does not always set properly and I have had some pieces come off. I must see how shoe-goo works. Are you using self-stick?
I went to the San Francisco area for the college graduation of my youngest daughter, which was quit nice but I had just modded my Stax Lambda 404 with 1/4 inch 70 duro sorb and was going through withdrawal symptoms. On coming back, the 404's are glorious. You really have to try sorbing the inside baffle of your lambdas.
yes Ed my sorb duro 70 are self stick....i dont give a damn for the veneer, i put sorb on it under some load of bricks
I trust you completely for your advise to sorb the inside baffle of my lambda....BUT now with my headband completely sorb with 8 paper clips for compression and 32 pieces of sorb duro 70 half 1/10 inches, the other half, 1/4 inches, the sound and imaging, and soundstage are so good that.... i cannot imagine that this would be better... I will try it after the sorbing of my new SR-5 gold coming in the next few days...congratulations for your daughter graduation...thanks for all ...
