Dali Zensor 3
  1. dauhak
    Hi ,
    I own Zensor 3 paired with an old Denon Avr 3133
    And my brother owns Kef q300 paired with yamaha v573
    I'm not sure are my speakers bad or is my Av receiver bad.
    I tested at store before buying(paired with marantz sr7005)
    I feel some type of distortion when playing at high volume, and the treble bleeds at times.
    And when I listen to my brother setup , that sounds amazing and musical.
    Could you suggest me good AVR for Dali Zensor 3 that will be musical and good 3D depth with instruments sounding natural.
  2. Felipe Cotta
    Hello,
    I've got a pair of Zensor 3 and now I really love them. I think it's important to say that, specially in the case of the Dalis, positioning is KEY.
    When I first unboxed mine and plugged it on my amp, I liked the sound but was not impressed. Excellent and super defined treble but no bass at all. Read some threads about it and lots of peolple said I had to wait for the "burn in" time.
    OK, while it may be true, I found out that experimenting with different places was the only thing that made a big difference.
    I only moved the shelf a few inches to the left and the sound of the Dalis opened up hugely! The difference was night and day.
    So So So much better!!! And now I love them, absolutely love them.
    Plenty of bass, PLENTY, and super defined, crisp treble and I'll never need a subwoofer with these speakers. They are GREAT.
    Just remember: if your first impressions are not good, try moving them around until you get the sweet spot where frequencies will not cancel each other, etc.
    These speakers can definitely SING. I recommend them very very much!
