Dac Help
post-15710132
Thread Starter
Post #1 of 9
AMONster23
Philippines
Philippines
Hi ya’ll. I have a noob question. So I recently got bookshelf speakers (B&W 606) paired them with the NAD3020 V2 amp. Connected via AUX on my PC. I was wondering what else can I do to improve my audio? Do I just buy a usb dac and connect it to my existing amp? How does it work? I will also be using HD6XX headphones. Will it work well, since I heard those are picky.
Thank You!
post-15710270
Post #2 of 9
TheTechQ
San Diego, CA
San Diego, CA
It looks like your amp has a DAC built in. It doesn't have any direct PC interface, so you couple of good options:
1) Use an external DAC to connect to AUX. A quality DAC should deliver better quality than connecting to the built-in sound on your PC.
2) Get an adapter to convert the USB from your PC to Coaxial or Optical. Audio quality would depend on the quality of the adapter and the DAC built into the amplifier.
Background information:
The audio out on your PC is a basic DAC. The problem is that the inside of your PC tends to be an electrically noisy environment, and depending on your machine, audio quality was likely not a primary design goal.
External DACs provide better noise isolation, and often have better components than what came with your computer. They can be under $100 to over $100,000. If you choose to buy a DAC, pick a budget and then look at reviews. There are many designs out there each with a set of fans and detractors. Listen to them in person if you have the option.
Upgrading:
The right upgrade can depend on what you are noticing about your system and what you want to achieve. For example, what kind of music do you want to listen to? Do you want fine detail, rich sound, etc. Adding a DAC (Schiit Bifrost 2) to my system added improved detail and eliminated the thin, fake sound that my headphone jack was producing. The first question is what does my system not do that I would like it to do? If you want less noise, better detail, or a more full sound, a DAC upgrade may be a good option for you.
Headphones:
Since I don't have your configuration, I would recommend taking a good listen to your equipment and seeing if it sounds good to you. I recently set up a system about 4x more powerful and found that to be adequate, but your mileage may vary. One nice thing about your amp is that it does have a preamp out that you could connect a dedicated headphone amplifier with whatever power you desire.
In summary, you could just get an adapter to use the amp's built-in DAC with coaxial and optionally add a headphone amplifier to get a bit more power on the headphones and be a very happy camper. If you want to go higher end, the sky is the limit.
post-15710290
Post #3 of 9
Mightygrey
Sydney, Australia.
Sydney, Australia.
Website
www.headfonia.com
Using the internal DAC from your NAD ought to yield marginally better results. Try connecting via USB.
post-15710983
Post #4 of 9
HBen
close to the alps
close to the alps
... I was wondering what else can I do to improve my audio? ...
The first thing you should do when using speakers is testing around placement of the speakers and play with room treatments. Have fun and good luck :)
Reactions: TheTechQ
post-15711173
Post #5 of 9
PurpleAngel
California
California
Turns out the NAD3020's USB port is a service port for stuff like firmware upgrades and not for a connection to audio sources.
post-15711175
Post #6 of 9
PurpleAngel
California
California
Thank You!
Use optical from your source (PC) to connect to the NAD.
Reactions: TheTechQ
post-15711342
Post #7 of 9
Mightygrey
Sydney, Australia.
Sydney, Australia.
Website
www.headfonia.com
Are you sure? I had the V1 of the D3020 and I had no problems using it as a USB DAC.
post-15711546
Post #8 of 9
PurpleAngel
California
California
I was reading the NAD 3020 V2 manual, page 6, lists the USB jack as a service port, says nothing about working as a normal USB port.
So it could be that USB jack also functions as a normal USB input, but the manual does not clearly state it.
post-15711601
Post #9 of 9
Mightygrey
Sydney, Australia.
Sydney, Australia.
Website
www.headfonia.com
Huh, there you go. The V1 had a USB DAC, but it seems the V2 doesn't. Does your PC have an optical output? If not, a Topping D10 might be a simple solution to send a USB signal to either the RCA-in or optical-in on your NAD.
