Nov 18, 2012 at 3:38 PM Thread Starter Post #1 of 8
VacantPlains
I am looking for a relativley affordable DAC (probably USB) for using my laptop as the source. I will be purchasing the M-Stage amp from Matrix and therefore won't need a DAC/amp combo. Portability isn't a huge issue either but I'm not opposed to something portable if it fits the bill and price point. I haven't decided yet on headphone but am leaning towards the DT 990s. Thanks for the help.
Nov 18, 2012 at 5:54 PM Post #3 of 8
I like the looks and price of the Fiio e10. Going to look into that a little more. Those are all around the price range I expected. I'm mostly just listening to music and the gaming that I do do doesn't require great locational precesion.
Nov 18, 2012 at 6:23 PM Post #5 of 8
I'm in the same situation as you: going to buy an M-Stage and need a DAC to pair with it.
I also came across the Stoner Acoustics UD100: http://www.head-fi.org/t/626632/tiny-dac-big-sound-impression-of-stoner-acoustics-ud100-vs-odac
Compares very favourably to the ODAC (which is often cited as outperforming its price range) and it's only $50.
Nov 19, 2012 at 12:33 PM Post #7 of 8
Would a combination of the e10 and M-stage be adequate to drive the DT 990s with 600 ohm impedence?
i love my E10, very good price for what you get. For the E10 with the M-stage, the E10 only acts as a DAC and passes the signal to be amplified by the matrix, which has more than enough power for the dt990s
Nov 19, 2012 at 1:07 PM Post #8 of 8
Look into ODAC and HRT MusicStreamer II. Avoid the uDAC 2, it's been known to have hardware issues.
